Topic: Come smontare la plancia di una Hyundai Coupe Turbulence (Letto 23202 volte) Topic precedente - Topic seguente
COME SMONTARE LA PLANCIA DI UNA HYUNDAI COUPE (TURBULENCE) PARTE 1 - HOW TO DISASSEMBLE THE DASHBOARD OF A HYUNDAI COUPE (TURBULENCE).
01 - STACCARE IL POLO POSITIVO DELLA BATTERIA - UNPLUG THE BATTERY POSITIVE CABLE.
02 - ESTRARRE L’AUTORADIO – TAKE OFF CAR RADIO.
03 - RIMUOVERE LA COPERTURA DELLA LEVA DEL CAMBIO, TIRARE VERSO L’ALTO – REMOVE BOOT ASSY-GEAR SHIFT LEVER, PULL IT UP, PART NUMBER 84680-27050.
04 - RUOTARE E NON RIMUOVERE LA COPERTURA DELLA LEVA DEL CAMBIO - TURN AND DO NOT REMOVE BOOT ASSY-GEAR SHIFT LEVER, PART NUMBER 84680-27050.
05 - RIMUOVERE LA PARTE CENTRALE DELLA PLANCIA, TIRARE VERSO L’ESTERNO – REMOVE PANEL ASSY-CENTER, PULL IT OUT, PART NUMBER 84771-27540CA.
06 - LA PARTE CENTRALE DELLA PLANCIA SENZA COPERTURA – DASHBOARD WITHOUT PANEL ASSY-CENTER, PART NUMBER 84771-27540CA.
07 - RIMUOVERE IL COPRI ALLOGGIO VITE, TIRARE VERSO L’ESTERNO – REMOVE COVER BLANKING, PULL IT OUT, PART NUMBER 84754-27000YN.
08 - SVITARE LA PRIMA VITE  DEL PANNELLO INFERIORE – UNSCREW THE FIRST SCREW OF THE PANEL ASSY-LOWER CRASH PAD, PART NUMBER 84750-27000YN.
09 - SVITARE LA SECONDA VITE DEL PANNELLO INFERIORE - UNSCREW THE SECOND SCREW OF THE PANEL ASSY-LOWER CRASH PAD, PART NUMBER 84750-27000YN.
10 - SVITARE LA TERZA VITE DEL PANNELLO INFERIORE - UNSCREW THE THIRD SCREW OF THE PANEL ASSY-LOWER CRASH PAD, PART NUMBER 84750-27000YN.
11 - SVITARE LA QUARTA VITE DEL PANNELLO INFERIORE - UNSCREW THE FOURTH SCREW OF THE PANEL ASSY-LOWER CRASH PAD, PART NUMBER 84750-27000YN.
12 - RIMUOVERE LA COPERTURA, TIRARE VERSO L’ESTERNO – REMOVE THE COVER-BLANKING RHEOSTAT SW, PULL IT OUT, PART NUMBER 94955-27000KW.
13 - SVITARE LA QUINTA VITE DEL PANNELLO INFERIORE – UNSCREW THE FIFTH SCREW OF THE PANEL ASSY-LOWER CRASH PAD, PART NUMBER 84750-27000YN.
14 - IL PANNELLO INFERIORE RIMOSSO - THE PANEL ASSY-LOWER CRASH PAD REMOVED, PART NUMBER 84750-27000YN.
15 - SCOLLEGARE LA PORTA OBD SVITANDO LE 2 VITI – UNPLUG THE OBD PORT UNSCREW THE 2 SCREWS.
16 - 17 - OPPURE STACCARE LA PORTA OBD PREMENDO SUI GANCI LATERALI - OR DISCONNECT THE OBD PORT BY PRESSING ON THE SIDE HOOKS.
18 - SVITARE LE 2 VITI DELLA LEVA COFANO MOTORE – UNSCREW THE 2 SCREWS OF THE ENGINE BONNET LEVER.
19 - 20 - STACCARE IL CAVO COMANDO TEMPERATURA ARIA - UNPLUG THE AIR TEMPERATURE CONTROL CABLE.
RINGRAZIO L'AMICO IVANO PER LA TRADUZIONE DI ALCUNE FRASI IN INGLESE.
Re:Come smontare la plancia di una Hyundai Coupe Turbulence
Fino a qui c'ero arrivato anche io... che dire... in attesa del resto la descrizione dei passaggi è da OVAZIONE!
Non avrei potuto far di meglio  (good) !
COME SMONTARE LA PLANCIA DI UNA HYUNDAI COUPE (TURBULENCE) PARTE 2 - HOW TO DISASSEMBLE THE DASHBOARD OF A HYUNDAI COUPE (TURBULENCE).
01 - SVITARE LA PRIMA VITE DELLA COPERTURA INFERIORE DEL PIANTONE DELLO STERZO – UNSCREW THE FIRST SCREW SHROUD-STEERING COLUMN LWR, PART NUMBER 84852-27100KW.
02 - SVITARE LA SECONDA VITE DELLA COPERTURA INFERIORE DEL PIANTONE DELLO STERZO – UNSCREW THE SECOND SCREW SHROUD-STEERING COLUMN LWR, PART NUMBER 84852-27100KW.
03 - SVITARE LA TERZA VITE DELLA COPERTURA INFERIORE DEL PIANTONE DELLO STERZO – UNSCREW THE THIRD SCREW SHROUD-STEERING COLUMN LWR, PART NUMBER 84852-27100KW.
04 - ABBASSARE LA LEVA REGOLA PIANTONE DELLO STERZO – LOWER THE LEVER STEERING WHEEL ADJUSTMENT.
05 - 06 - RIMUOVERE LA COPERTURA INFERIORE DEL PIANTONE DELLO STERZO, TIRARE VERSO IL BASSO (ATTENZIONE POSSIBILE ROTTURA DEI GANCI) - REMOVE THE SHROUD-STEERING COLUMN LWR, PULL IT DOWN, (CAUTION POSSIBLE BREAKING OF THE HOOKS) PART NUMBER 84852-27100KW.
07 - PIANTONE DELLO STERZO SENZA COPERTURA - STEERING COLUMN WITHOUT SHROUD-STEERING COLUMN LWR, PART NUMBER 84852-27100KW.
08 - RIMUOVERE  LA COPERTURA SUPERIORE DEL PIANTONE DELLO STERZO, SOLLEVARE - REMOVE THE SHROUD-STEERING COLUMN UPR, TO LIFT IT, PART NUMBER 84851-27100KW.
09 - PIANTONE DELLO STERZO SENZA COPERTURA – STEERING COLUMN WITHOUT SHROUD-STEERING COLUMN UPR, PART NUMBER 84851-27100KW.
10 - SVITARE LA PRIMA VITE  DELLA PLANCIA – UNSCREW THE FIRST SCREW OF THE COVER-TILT, PART NUMBER 84832-27000.
11 - SVITARE LA SECONDA VITE  DELLA PLANCIA – UNSCREW THE SECOND SCREW OF THE COVER-TILT, PART NUMBER 84832-27000.
12 - SVITARE LA TERZA VITE DELLA PLANCIA – UNSCREW THE THIRD SCREW OF THE COVER-TILT, PART NUMBER 84832-27000.
13 - SVITARE LA QUARTA VITE DELLA PLANCIA – UNSCREW THE FOURTH SCREW OF THE COVER-TILT, PART NUMBER 84832-27000.
14 - SVITARE LA QUINTA VITE DELLA PLANCIA – UNSCREW THE FIFTH SCREW OF THE COVER-TILT, PART NUMBER 84832-27000.
15 - SVITARE LA SESTA VITE DELLA PLANCIA – UNSCREW THE SIXTH SCREW OF THE COVER-TILT, PART NUMBER 84832-27000.
16 - RIMUOVERE LA PLANCIA, TIRATE VERSO L’ESTERNO – REMOVE THE COVER-TILT, PULL IT OUT, PART NUMBER 84832-27000.
17 - SCOLLEGARE L’INTERRUTTORE FENDINEBBIA E RETRONEBBIA, PREMERE E SFILARE – DISCONNECT SWITCH ASSY-FR FOG LAMP AND SWITCH ASSY-RR FOG LAMP, PUSH AND PULL IT OUT, PART NUMBER 93740-27500 AND 93730-27500.
